lca relocation brackets
Old Sep 14, 2002 | 10:49 AM
tpiz28's Avatar
can anyone that has used the lca relocation brackets tell me how much lower than oe thay mount the lca's. looks like stock from the bottom of the axle tube to the bottom of the mounting hole is appox. 2 inches. any info would be appreciated! I installed a Moser 9 inch rear in my 89 z and have had terrible wheel hop that i never had before??
thanks tpiz28
Old Sep 14, 2002 | 03:36 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Welcome to Thirdgen.org!
I just measured my BMR Weld In brackets. The 1st set of holes is 2" lower than stock, and the 2nd set of holes is 3" lower than stock. Measurements are probably consistant with other brands of brackets.
Old Sep 16, 2002 | 10:44 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Welcome!
You want the LCA to be parallel to the ground. Pick the holes accordingly.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
