Rear Swaybar ???
Old Sep 15, 2002 | 12:56 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
Rear Swaybar ???
I am replacing the rear swaybar with a BMR piece & have a question?
Does the part of the bar that bends out around the axle cover go up toward the car or down toward the ground?
Old Sep 15, 2002 | 02:49 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Down.
Lon
Old Sep 16, 2002 | 12:27 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
did you also get the matching front bar? if you didnt and the new rear bar isnt the same strength as original your handling will get screwy- under or oversteer.
Old Sep 16, 2002 | 01:22 PM
Car: 1987 Z28
Engine: LG-4 305
Yes I got both BMR front & rear & got it figured out (I think),
One thing that has me puzzled was the slit in the poly parts where the bars actually mount to the car. The manual shows the slit to go toward the front of the car & says the same for the rear poly parts. Is this correct?
Old Sep 16, 2002 | 01:25 PM
lonsal's Avatar
Slit facing forward is correct.
Lon
Old Sep 16, 2002 | 01:31 PM
Car: 1987 Z28
Engine: LG-4 305
Lon
Why would someone else tell me that rear poly parts slit should fact the rear of the car, or are they just not sure???
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
