Where can I buy replacement IROC springs?
Old Sep 19, 2002 | 12:59 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
My car's suspension has sagged a little bit over the past 16 years, and I'm planning on replacing the springs. Being that I have an IROC, my springs are stiffer than the other Camaro models. Would an auto parts store have IROC springs, or just the "standard" springs? Or, are there aftermarket springs that I could go with? I want my car to remain the stock height.
Old Sep 19, 2002 | 04:34 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check out eatonsprings.com.
JamesC
Old Sep 19, 2002 | 05:03 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
MOOG sells replacement IROC springs (and base model) throught Checkers or AutoZone...
Old Sep 20, 2002 | 04:11 PM
turtle's Avatar
on the eastcoast they are sold through advance for dirt cheap, moog springs i mean. just installed a set on my iroc's rear a couple weeks ago and man are they stiff.
Old Sep 21, 2002 | 06:46 PM
napa dude's Avatar
Car: 1991 z/28
you can also get them from napa
Old Sep 22, 2002 | 07:19 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I got mine from NAPA, they are re-boxed Moog. Good parts.
Look up your car, and get the diameter, installed height (that's the height of the spring, not the car), and the type of ends; then go to the buyer's guide in the back of the catalog and find the stiffest ones you can find with a somewhat lower installed height than your stock listing, and the highest "rate" possible. I can tell you, there's one part # that will jump out at you, it's got a rate of about 700-some lbs/in; that's the one you want.
Old Sep 23, 2002 | 01:40 AM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
YUP.
Got Mine from NAPA too, cheap, like 80 bucks for the front, 60 for the back.
customblackbird
Aug 15, 2021 10:16 PM
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 25, 2015 07:34 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
