which is the better caliper set up
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
Which is better, the caliper on the trailing side or the leading side? Why so some companies switch it around?
can I move the caliper on a 9-bolt if I move the backing plate around? I know I would have to change the lines
Anyway, I decided to leave it alone because I figured that GM engineered it that way for some specific reason otherwise they would have put it on the back side like the other (and all the replacement parts fix to it that way like you said).
ambainb
Apr 25, 2016 09:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Genopsyde
Nov 11, 2015 10:46 PM
red90IROCls1
Aug 25, 2015 06:56 AM
