How much wheel bearing movement is excessive?
Old Sep 25, 2002 | 04:40 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
I had the car at an alignment shop today and they said it couldn't be aligned because there was excessive play in the wheel bearings. They wanted $45 to tighten the bearings just so they could do a $50 alignment job. Needless to say, i picked up the car and decided to do that much myself. I havent looked at it today, but last time i checked, the bearings seemed rock-solid.
so the questions stands, how much motion is deemed "excessive?"
Old Sep 25, 2002 | 05:15 PM
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Re: How much wheel bearing movement is excessive?
If you can hear it pretty bad (jack up one corner of car and push/pull on the top of the tire), it means the wheel bearing is pretty bad. It will make a "clunk" sound when pushing or pulling. The alignment probably still could have been done, but it's one of those things the techs are programmed to do -- take your money if any little thing is wrong.
I haven't worked on a 3rd gen much (yet) so I don't know how hard of a DIY project that is.
Old Sep 25, 2002 | 05:29 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
any is excessive. the reason why they can not do an alignment is because with loose wheel bearings, you get a wrong camber reading. loose wheel bearings cause the tire to lean inward from the top. and with a wrong camber reading, you get a wrong toe reading. it may be worn ball joints if the wheel bearings are tight.
Old Sep 25, 2002 | 11:37 PM
Car: 82 Trans am
Im going to throw it on some jackstands tomorrow and check it out. Everything in the suspension is new, and i mean EVERYTHING, just check my wallet. Ill tighten them down and see what the shop can do then.
Thanks for the replies
Old Sep 29, 2002 | 12:05 PM
SgtSkip's Avatar
While we're on the subjest, what's the best way to tset wheel berings? Push/pull on the top of the tire like my dad says??
morrow
Jan 13, 2024 12:29 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
mrdevontay
Sep 2, 2015 08:04 PM
1HotZ28&SS
Brakes
Sep 1, 2015 04:33 AM
