torque arm bushing and b&m changeover kit
Old Sep 25, 2002 | 08:54 PM
84camarojs's Avatar
what torque arm bushing do i need to use with the B&M TH-350 changeover kit. The stock one from my 1984 camaro 5-speed doesnt sit against the torque arm and it bangs against the bracket and is annoying. Does anybody have this kit and what bushing did they use. Thanks.
Old Sep 26, 2002 | 04:33 AM
ede's Avatar
ede
i think b&m gives you the pn i nthe instructions don't they?
Old Sep 26, 2002 | 09:58 PM
84camarojs's Avatar
my fault, it is a hurst kit, wouold the p/n from b&m still work? if so what is it?
Old Sep 26, 2002 | 11:27 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I have the B&M kit on mine. I just ordered a poly bushing made by energy suspension. I used one of the later model ones, not the '82-'83 torqque arm bushing they make but one of the newer ones that differs depending on which way the torque arm lip faces. Mine fits REAL tight. Had to use a "c" clamp to squeeze the thing enough to run the bolts through. The bushing is only $20 and poly on top of that so just a suggestion.
HTH,
Old Sep 27, 2002 | 06:49 PM
84camarojs's Avatar
what is the lip?
Old Sep 27, 2002 | 07:20 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
The lip is on the top and bottom edge of the torque arm. So if you were looking at the torque arm bushing from the rear it will have a cut in it for the torque arm. I'll try and attach a pic from energy suspension's web site for ya. Well this is from summit's site. In the upper right corner you can see the end of a torque arm. It makes kind of an "m" shape. Which way that faces (either towards the driveshaft or away from it) determines which part you need.
Attached Thumbnails torque arm bushing and b&m changeover kit-ens-3-1111r.jpg
morrow
Jan 13, 2024 12:29 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
deracer
Apr 11, 2016 12:04 AM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
