calipers rubbing on my wheels
Old Sep 26, 2002 | 11:39 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
I have a pair of 79 snowflake wheels on my 82 trans am.
I just installed an 89 9 bolt with pbr rear calipers. The little fins rub on the inside of my wheels. They are 15 x 7 I think. They could be wider like 15 x 8's or so. Can I just shave off the fins right where the caliper has that bend? I know they are for heat disipation, but I don't care. I don't want to have to buy new wheels. could I spacer them out. I figure that would make the wheels not rub on the calipers, so I figure I could have a nice bull dog stance also.
donesn't anyone else have old trans am wheels with a newer 9 bolt??? I have never heard this being addressed before.
Old Sep 27, 2002 | 07:06 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The backspacing isn't correct fot those wheels and those brakes. You could try and run a set of small spacers before you go grinding on your calipers, that would push the wheels out a bit, possibly enough to stop them from rubbing.
Ed
Old Sep 27, 2002 | 08:18 AM
where can I buy the correct spacers. Ed? Should I try to make my own? What about putting wide washers around the studs on the axle?
If not, what size spacer should I need? will a 1.75" work?
Old Sep 28, 2002 | 02:12 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Use GM part# 14091902 They are approx. 1/8" thick. Get only one and try it first. The spacer is steel, not aluminum.
Thanx,ANDYZ28
Old Sep 30, 2002 | 06:11 AM
ebmiller88's Avatar
I got a set of these spacers with the '89 9 bolt I bought, and my '91 RS with a drum rear also has a set on it. You could probably find them in a scrap yard, a 3rd gen parts seller, or just buy them from GM. They can't be that expensive.
Ed
Old Sep 30, 2002 | 05:44 PM
I just added some really wide washers on to the studs. It can't be good, but I check the lugs all the time. The rim still rides on the hub, and the lugs go on all the way. I don't know what else could cause a problem, but I think I am okay now.
I have driven on it for the past 2 days, with out a problem. The thing is when I notice a problem, it will probably be to late.
What do you guys think
They are the standard thickness washer, and I used two per stud. like I said the wheel is still on the hub, and I don't see any wear.
Am I safe?
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rb85TA
26
Sep 14, 2015 10:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
TheExaminer
Sep 6, 2015 11:40 PM
rudolphschenker
Sep 4, 2015 02:41 AM
