Why are the front/rear spring rates so different?...
Old Sep 27, 2002 | 05:20 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Like the ground controls that I have. 800lbs in the front and 175lbs in the rear. Why are they so far apart? When I try to think of it this would cause the rear to feel apart from the rest of the car. (which my car seems to be like) because the front would roll only a bit. While the back end would roll alot. From what I know the weight at each front wheel is around 1000lbs. and the weight at each rear is about 680lbs. So it makes me wonder why the front would be 200lbs less then the weight. And the rear would be 500lbs less O_o. Even the eibach prokit, sportline, intrax, etc. they all have this extreme difference in front and rear also. I'm confused as to why they set it up this way. I'm considering ordering new springs for the rear. Probably about 500lbs for the rear.
Old Sep 27, 2002 | 05:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well for one thing the fronts don't compress the same amount as the suspension travel; only about 1/3 as much. So that 800 lbs/inch at the spring is only about 275 lbs/in at the wheel. The rears don't have a leverage situation.
Old Sep 27, 2002 | 08:32 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
how about the engine up front when braking it transfers about 85% weight towards the front. so to keep the front from nose diving you need a high rate spring. with the rear, you have very little weight. so you don't need near the same amount of spring rate to control the rear.
87v6Bird
Jul 1, 2018 04:12 PM
BumpaD82
Feb 26, 2016 02:57 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
sandman92084
Sep 12, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
