Adjustable panhard bar problems>>>
Old Sep 27, 2002 | 09:56 PM
CGCBandit's Avatar
Hey everyone, after putting on my adjustable pbar, the rear feels looser now, I tried to match the length of the the factory one, but it just doesn't feel stable in the rear any more?? Which way do I need to adjust it to make the rear tighten up?(make the bar shorter/longer)?PLEASE ANYONE??
Old Sep 28, 2002 | 12:27 AM
chacane67's Avatar
Well I have a question for you...has the car been lowered?
If it has, you will need to shorten the bar. Reason: The car is shipped from the factory at a set ride height. When you lower the chassis, you effectivly move the entire differential to the left. It also will change the rear alignment (rear tracking). So when you jump on it, in its geometry it over compensates for the alignment difference realitive to thrust.
Put the car on a flat surface. Loosen the pan hard rod. Measure the outside of the wheel to the rear subframe (factory not a subframe connector). Adjust the bar until its centered, and remember to check it after you have completed tightening the jam nuts.
Old Sep 28, 2002 | 08:50 AM
CGCBandit's Avatar
Nope, I havn't lowered it at all, stock ride height!
Old Sep 29, 2002 | 12:03 AM
sllt1776's Avatar
Car: 89 Iroc-Z
the pan hard is mostly to hinder side movement. adjust the bar so that the rear is centered. thats the main idea.
Old Sep 29, 2002 | 02:12 AM
AFrikanGoodTime's Avatar
Just to verify--- you didn't remove the panhard rod brace did you? That would be the stamped metal bar that runs paralell and directly above the panhard rod.
Old Sep 29, 2002 | 09:18 AM
CGCBandit's Avatar
No, I havn't touched the brace.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Nervous2
Oct 8, 2015 10:53 PM
loud91rs
Oct 5, 2015 10:05 PM
