front end sits too high
Old Oct 2, 2002 | 11:42 AM
oldschoolz28's Avatar
just installed a front end rebuild kit on a 1985 z28. new ball joints, bushings, tie rods and sway bar links. it still has the stock springs and struts. anyway, after it all got put back together the car sits about 1 1/2 inches too high and it is messing up the camber (i think). does any one have any ideas on why this may be or is there an adjustment for it???
Old Oct 2, 2002 | 12:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Make sure the car is sitting on the ground in its normal manner (i.e. weight being carried by the wheels), and loosen the control arm bushing bolts and re-tighten them while it's in that position.
Nothing in your list should change the ride height measurably. Maybe 1/16", tops, if your old ball joints were literally ready to fall apart, that's about it.
Old Oct 2, 2002 | 08:53 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You probably have one of two things wrong:
1- You don't have the springs indexed correctly in the A-arm. They must be installed in the correct position.
2- The springs aren't fully inserted in the "bucket" in the top of the K member.
I'd check these 2 things first.
For indexing pics, look at my rebuild here:
http://photos.yahoo.com/taramiller72
Click on the Camaro albums. HTH...
Ed
Old Oct 4, 2002 | 01:01 PM
thanks for the info. now i know what i'm doing this weekend.
Old Oct 6, 2002 | 03:16 PM
Mission accomplished! The springs were in exactly opposite the index marks, so, spun 'em around and everything looks great. Thanks for your help and the pics were awesome.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
kyleb24
Aug 15, 2015 08:24 AM
