sfc installation question
Old Oct 5, 2002 | 09:04 AM
Nasty_Bird_'90's Avatar
Should sfc's be installed with the suspension loaded, or can they be done on a lift with in unloaded?
Old Oct 5, 2002 | 10:10 AM
ede's Avatar
ede
loaded and on a level surface ,not the car the level ,because it doesn't set level normally, but if you use jack stands they should be on a level surface. if you do use jack stands it's a good idea to get some referance measurements and replicate them when you raise the car ,use plywood shims or something similar under the jackstands.
Old Oct 5, 2002 | 01:02 PM
Jeffbird's Avatar
ramp hoist...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
