brake upgrade ?
Old Oct 6, 2002 | 09:40 PM
BitchinRS's Avatar
brake upgrade ?
I want to upgrade the front brakes on my camaro and was just woundering if some one could throw out a few manufacture names so I can look them and do some research on them?
1992 RS 3.L w/ 5 speed
Old Oct 7, 2002 | 01:57 AM
pianiy's Avatar
Check Spohn's site for the 1LE upgrade kit - link is at the top.
Baer makes good kits similar to the 1LE upgrade and they work excellent for the money.
Alcon is in the brake business but I'm not sure if they have anything for our cars. Search for them though.
Old Oct 7, 2002 | 08:36 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
baer sells kits with the alcon calipers, but the price is 2k+ to step into a kit with alcons.
the other baer kits use a PBR caliper, like the 1le kit, but you can get them with a 13" rotor.
Old Oct 7, 2002 | 10:18 AM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
If you want a stock 1LE conversion, there is one on eBay right now. That is the same stuff that Spohn is selling. You never know, you may get it cheap. This ain't my auction, I just saw it earlier today. See it here.
Since I have Bell Tech lowering spindles, I'm going to go with the Baer Track system (13" rotors & PBR calipers.) It's about $1100, that's only $300 more than Spohn's 1LE and I'll be running 13" rotors.
Old Oct 8, 2002 | 06:22 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
1LE man. Look no further.
Ed
Old Oct 9, 2002 | 04:06 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
1LE brakes are good,Baer and Stainlees Stell brakes both make great brake upgrade kits for our cars also. I have the 13 inch Baer track system and love it. Performs great.
Old Oct 9, 2002 | 04:44 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Ok, so what's the deal...
I've seen a few pictures lately of the Baer front disc setup, and every one looks like the inner 1/3 of the rotor is untouched by the brake pad. Is there some sort of clearance issue with the spindle/caliper that does not allow the caliper to go farther down on the rotor or allow the use of a larger caliper, or is this how Baer intended it to be? I realize that some of the surface loss is made up by the use of a larger diameter rotor, but it seems rather inefficient to have almost 1/3 of your rotor surface not utilized.
Old Oct 9, 2002 | 07:08 PM
chacane67's Avatar
Larger diameter rotor means a greater leverage angle. Pad contact is importaint, but the leverage angle is what attributes to greater overall brake performance. A larger caliper will allow a larger brake pad, allowing more frictional surface aera, but a larger rotor diameter will give you a greater effictive leverage ratio.
Old Oct 10, 2002 | 12:25 AM
pianiy's Avatar
This the same on my converted 1LE setup. In order to cover that last bit the caliper would have to be larger, and the anchor bracket that holds it would have to increase in size as well - length wise and sit farther down closer to the center of the spindle. Its probably possible, but there may be interference issues with the spindle as this happens, not to mention more weight.
Billy Decker
Sep 4, 2015 03:46 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
