All you Weld Draglite folks, a couple of questions w/in...
Old Oct 9, 2002 | 02:04 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I'm gonna run Draglites in the rear but wanna know, will the stock wheel studs be okay to use or do I need longer ones? If so, what size should I use? The draglites will be a track only thing, so I'm gonna switch between the stock IROC wheels and Draglites. I'll be using Weld's long shank lug nuts (closed end) and washers but I'm just not sure if the stock wheel studs will pass tech with the Draglites.
Thanks for any suggestions
Old Oct 9, 2002 | 08:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You're going to need 3" long wheel studs on those rims to pass a tech inspection. Upgrade to 1/2" studs instead of the factory 12mm ones.
Old Oct 10, 2002 | 07:50 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Thanks for the reply Stephen, I'll give that a shot.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
