Which suspension package is better WS6 or Iroc?
Old Oct 10, 2002 | 02:43 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
Just curious why GM put a hollow 34mm and wonderbar on the Iroc package and a 36mm hollow with no wonder bar on the WS6 package. Is that the only difference between the two?
Old Oct 11, 2002 | 12:52 PM
MdFormula350's Avatar
you want the wonderbar regardless, i hear it helps alot.. by connecting the front frame rails together and keep the steering box from cracking the frame where it mounts too..
but as far as i knew the suspensions used the same size sway bars.. the ws6 was the name for the firebird performance suspension and the iroc-z had the camaro performanace suspension..
i have no clue why the firebird did not have the wonderbar at all, but the only camraos that did where the iroc-z i guess they were special..
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
mustangman65_79
Aug 11, 2015 03:17 PM
