Gear Ratio Help Needed
Old Oct 11, 2002 | 11:01 PM
Harley83's Avatar
Im running a 15x8 inch wheel in the back with 275/60/15's and 15x5 205//70/15 in the front. The motor is a Chevy 355 throwing out about 430 horses and Im looking for a better rear gear maybe 4.10's? any suggestions appreciated.. By the way the transmission is a 700R-4 and is used for daily driving
Old Oct 12, 2002 | 05:29 AM
ede's Avatar
ede
with a OD trans 4:10s would be ok, be a lot of gear for the street but it'd work. 3:73s is the popular choice for most people here.
Old Oct 12, 2002 | 12:34 PM
chacane67's Avatar
I concur with ede......
Old Oct 12, 2002 | 02:24 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I also agree with ede.
Thanx,ANDYZ28
Old Oct 13, 2002 | 05:43 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If he's gonna be running 275/60-15's that is a 28" tall tire, the 4.10 or 4.11's would be the ultimate gear of choice for that. If he was running 275/50-15 26" then yes the 3.73 would be a better match. If his HP #'s are correct and if he ever wants to drag it, he'll never use the full motor in the 1/4, he'd probably only tach about 45-52 hundred depending on stall and cam. For a daily driver that will never see the strip stay with the 3.73 and you'll have a good all around gear. Depending on how light his car is he could easily get away with 3.42's, if it's 3300lbs or lighter.
IROCZ1989
Jan 24, 2016 03:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
