Brake pedal noise
Old Oct 14, 2002 | 01:02 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Brake pedal noise
When I press the brakes i hear a 'ppshhh' noise.
I dont think its normal.. The level of fluid was real low
(and pedal travel was deep) so I added fluid.. but after the brake
pedal was still low.. and that noise is constant..
The fluid reservoir isnt clear either.. it seems like there's
a build up of dust stuck inside .
I guess I should empty it.. clean it.. then bleed the system..
What should I do ?
Thx for ur responses
p.s how are 3rd gens supposed to brake with stock parts?
Old Oct 14, 2002 | 01:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like your master cylinder leaks, and the fluid has killed the booster.
So before you bother with any cleaning and bleeding, replace the booster & MC; they are available as an assembly.
Most of these cars have pretty good brakes, except that they kind of fade alot with hard hig-speed usage.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
