Sway bar or no?
Old Oct 14, 2002 | 10:16 PM
AFast83z28's Avatar
Sway bar or no?
i need some input on this subject. not sure on whether to remove it, keep stocker, or buy a bgiger one
Old Oct 14, 2002 | 10:43 PM
ronterry's Avatar
Car: '94 Corvette
Get a balanced set for front & rear, and you can't go wrong.
Spohn sell a kit with both...The kit runs $275.00...
I'll be getting that kit soon....
If you replace only the front bar, with a bigger one- the car will be lose.
If you replace only the rear bar, with a bigger one- the car will be tight.
If you take off the front bar, and leave the rear -the car will be tight.
If you take off only the rear, and leave the front -the car will be lose.
If you remove both, -well than you have a car that corners like mini van.
Ron
Old Oct 15, 2002 | 03:11 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
counts what your going for handling, drifting, drag, etc. From what I read though sway bars shouldnt be bought. A stiff suspension is better then sway bars.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
