Koni reds or yellows?
Old Oct 20, 2002 | 01:42 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Anybody tell me which one is better for a street car.How do they compare etc.Thanks
Old Oct 20, 2002 | 04:33 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
isnt the reds adjustible? and the yellow non adjustible? well to me I'd buy which ever one is adjustible.
Old Oct 20, 2002 | 05:24 PM
german-motorsport's Avatar
Hello Europe!
Red or yellow are both ok for the street!
The yellow ones are adj.!
The yellow ones also came on the 1LE 4th gen as stock units!
Use the red if you have 15" rims take the yellow if 16 and up is your rim size!
The yellow ones are firm, if you still have the gm units in there ......swap to KONI!
If you wanna get firm skip the red ones!
When we bought rancho units i first thought the shock was used, but again speeding in the USA with 55 miles, i guess you only need those cheap a.. gabriels !
As we do speed offic. up to ...no speedlimit...take the yellow ones and smile!
We just got a rear red unit for a member with a 85 Firebird!
Old Oct 20, 2002 | 05:35 PM
Lounge Lizard 6's Avatar
My reds are adjustable. The fronts came with a slip on ****, too. What I don't like about the reds are the lack of distinct stops or clicks. Twist the **** or in the case of the rears twist of the wrench. I don't know if the yellows are set up the same way or not.
Old Oct 21, 2002 | 01:09 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I have the reds as well and they are adjustable, I thought the yellows were not adjustable. I was also told that I shouldnt get the yellows on a daily driven car as they are way to firm. :shrug:
Old Oct 21, 2002 | 08:15 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I'm running yellows in the front and reds in the back. The softer setting of the reds should alow better planting of the rear end when coming out of corners. I got this setup because TireRack screwed up, but several veteran autocrossers thought this may be better setup. I've run them all year and cann't complain.
Old Oct 21, 2002 | 04:24 PM
01 FS Z28's Avatar
Both Koni Specials (red) and Sports (yellow) are adjustable. Both adjust only rebound. Double adjsutables have to be made out of singles and are not available off the shelf for a 3rd gen.
Basically the bottom 1/3 of the range on a yellow is akin to the top 1/3 of the range on a Red. The bump setting is very close on both, and again not adjustable.
No Koni fronts have clicks on the rebound adjuster, only one Koni for a 3rd gen (out of 3 available) has clicks.
'Tis true that Koni yellows came on the 4th gen 1LE, but they are TOTALLY different shocks both front and rear than the 3rd gen units. Completely different valvings (and in the case of the front the whole design itself).
I've run them all. Bilstein, Koni's (both) Tokico's (both)..... I prefer the Bilstein's for both street use and autox. I won a lot of National level events with Bilstein on my cars..
'91 1LE
'82 Z28 (not mine, but won National Championship in it this year)
'01 Z28 (mine '02 F-Stock ProSolo champion)
Linson
Oct 24, 2025 02:00 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
LT1Formula
Oct 8, 2015 08:34 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Dragonsys
Sep 25, 2015 03:51 PM
