Non PBR Caliper Leaking! help
Old Oct 20, 2002 | 03:34 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Rear Caliper Leaking BAD!!!!HELP
Hey guys.
I just put in a '88 9 bolt with the old style non PBR calipers into a original drum car.
The problem is one of the calipers is leaking from where the e-brake lever bolts to the rotating hex stud on the back of the caliper.
There is a rubber washer/seal that gets sandwiched in between the lever and the caliper that is supposed to seal it I guess.
I get it as tight as I can, and it still leaks pretty bad.
Is it the rubber washer or the caliper? is there something out of adjustment?
I am new to these brakes so I don't know where to start.
The calipers are remans from Oriely's.
I'll try to put up some pics.
thanx in advance
Old Oct 20, 2002 | 03:55 PM
Car: Damn
Engine: This
here's a couple pics.
Old Oct 20, 2002 | 03:57 PM
Car: Damn
Engine: This
It leaks from the ?e-brake shaft?
Old Oct 21, 2002 | 11:02 PM
Car: Damn
Engine: This
Please? ttt
Old Oct 21, 2002 | 11:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yeah looks like the seal is leaking. If they're new I'd return them.
Old Oct 23, 2002 | 05:48 PM
Car: Damn
Engine: This
Its some kind of rubber crush washer that gets mashed between the caliper body and the e brake lever.
I stripped out the threads in the caliper for the brake line bolt anyways, so i got a new calper. No problems with this one!
thanx
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
mfp189
Sep 27, 2015 09:25 AM
