Eibach sportline or prokit?
Old Oct 26, 2002 | 03:05 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I've read on this board that sportline springs may be a bit harsh for a street car.Whats the lowering height of each?how do they fare over speedhumps?(very important in this country).Do prokit springa match well with Koni yellows or Bilsteins.Ta muchly
Old Oct 26, 2002 | 03:18 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
The pro-kit lowers your car 1-2 inches while the sport lines lower1 3/4-2 1/4. Most people I have talked to said the sport lines suck as far as handling compared to the pro kit. I have the pro-kit with Koni reds and the ride is very firm. It handles great.
Old Oct 26, 2002 | 08:46 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
http://www.eibach.com/index1.htm
Unless you really want to scrape the car all the time, go with the Pro-Kit.
Here's mine with the Pro-Kit. I have 1 1/2" fender gap in the front, 2 1/4" in the rear.
Ed
Old Oct 26, 2002 | 10:32 PM
Garett92Z's Avatar
I'm normally not a fan of big lowering jobs, but this time I am going with the Sportlines.
Too many people have complained the pro kit doesn't lower it enough, some have even said as little as 1/2" lower than their stock height before (sagged-out stock springs).
There was a discussion about this a while back and the sportline springs handle JUST as well as the pro kit, some even argued better.
Old Oct 26, 2002 | 10:50 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I have Sportlines in mine and love them. I drove the car daily for years with those springs. Now it is not a daily driver , so I can do whatever I feel like with it, but most likely will leave it as is. The ride is very good, handles very good, etc. I have no bad things to say about the sportlines. I am running Koni struts too and Bilstien shocks in the rear.
Old Oct 26, 2002 | 10:51 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Another look...
Old Oct 26, 2002 | 10:53 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
And...
Old Oct 26, 2002 | 10:56 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Lastly...
Old Oct 27, 2002 | 12:25 PM
MdFormula350's Avatar
those pics are great, i have fender gaps and they look ugly.. i guess i need to lower the car..
Old Oct 27, 2002 | 05:17 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
The eibach prokit is a noticable drop. The reason most people say its not super big of a drop is they usually had dead springs and struts/shocks. And then they pop in the new springs and struts/shocks. Thats usually what I see. Dropping a car to low will cause a bad suspension and steering set up. 1" is about a good drop height to not only lower the center of gravity but to also not really affect anything. Personally I'd go with the prokit if you want performance. And the sportline if you want more looks.
Old Oct 27, 2002 | 06:22 PM
ebmiller88's Avatar
RU, I love that color blue. Nice rides you have there.
MD, nice car, too. That fender gap becomes a bit obvious when you see those lowered cars. I was set that I wasn't gonna lower mine either, but I'm so glad I did...well worth it.
Ed
Old Oct 29, 2002 | 09:31 AM
MInotaur15's Avatar
Car: 86 Monte Carlo SS
Engine: L69
Weight?
Did you guys notice the eibach products to be considerably lighter than the stock springs, particularly the front? Anybody get hard data from Eibach on the spring rates of these kits? What's the wire diameter of the front springs?
Old Oct 29, 2002 | 01:43 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I was VERY happy with the Eibach Sportline Springs on my 1991 Z28.....looks really aggressive.....and I've never bottomed out..... they made my car handle alot better.
Old Oct 29, 2002 | 03:16 PM
Car: '92 RS Camaro
Transmission: TH400
I love threads like this,I go away even more confused than what I started!!!Thanks anyway,I suppose people have different views on most things on this board
Old Oct 29, 2002 | 03:23 PM
Steve89GTA's Avatar
Get the pro kit and cut half a coil on the front and .25 off the rear. You'll be set, trust me!
Old Oct 29, 2002 | 03:57 PM
Engine: 5.7
Um.....why would you do that for????
Old Oct 29, 2002 | 04:03 PM
Steve89GTA's Avatar
Some guy with an IROC did it to his pro -kit (complained it wasnt low enough) and it looked nice.
Just a suggestion. Personally, I like stock ride heights.
Old Oct 29, 2002 | 04:16 PM
Engine: 5.7
Oh, that's kewl.....but....I think that would be crazy to cut up a brand new set of springs....if anyone wants a lower ride....go with the sportline.....as you can tell by the pictures.....they look awesome!
Old Oct 29, 2002 | 04:24 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Every lowered gen3 I've seen needed a little cut on the rear spring while the front looked fine.
Old Oct 29, 2002 | 08:51 PM
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
what about just cutting the stock springs? i just want my cars wheel well to sit right on top of the tires pretty much, i have 245/40/18's and i NEED to lower it, I think it would look alot better if i lowered it. anyone ever done this? its cheaper!
Old Oct 30, 2002 | 08:41 AM
Engine: 5.7
I have never doen it before......but I have talked to some people about it......and they said that it makes your car ride like sh*t.
Old Oct 30, 2002 | 09:30 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well their def. of **** may be diffrent then mine....
by cutting the stock springs, you make them "stiffer", personaly i like stiff, i am driving a camaro , not a lincon.
you can cut stock springs, it will lower the car, and make the springs stiffer.
i would recomend buying a new set of springs instead though.
Old Oct 31, 2002 | 07:21 AM
ebmiller88's Avatar
84customz28, doing this would probably take care of the rake that I have on my car. I posted a pic of it earlier in this thread.
Ed
Old Oct 31, 2002 | 07:52 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I don't know guys, look at RU-QWIK's, that's the stance I see most on 3rdGens. Looks to me like if you lower the front anymore it'll be tire rub time while the back could use a 1/4 to 1/2 coil off. Whaddaya think?
Old Mar 30, 2011 | 10:40 AM
nalls426's Avatar
Car: 1991 Rs Camaro
Engine: 5.3l h/c/i
Transmission: t56
Re: Eibach sportline or prokit?
never cut the springs. they all have a lbd rate for each spring and your throwing that off and going to make your car ride like a**. ya it may make it more stiff but its going to handle like Sh*t everywhere you go!! its going to bounce and has more of a chance of bottoming out. just get the sportlines and shocks and struts that have a good rebound so it doent bounce all over. if you want to spend a lot of money on springs get Ground Control Weight Jacks that are fully adjustable and you tell them how you drive the car and what you want out of it and they will set a spring rate up for you, and if one day you want it lower than yesterday then you can lower it al the way around.
Old Mar 30, 2011 | 11:14 AM
rsmk8522's Avatar
Car: 86 Trans AM
Engine: 350.. Carb
By Putting the Eibach Pro springs on, will that effect clearance for 17X9.5 wheels on the car?
Old Mar 30, 2011 | 11:35 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The Eibach Sportlines with Koni reds set on 2 make a very aggressive suspension. They are not for everyone. Most would consider the ride harsh. It lowers the center of gravity for the best cornering capabilities. My alignment guy was just able to zero the camber. I had to cut one coil from the rears to attain a level stance.
Old Apr 17, 2011 | 09:49 PM
nalls426's Avatar
Car: 1991 Rs Camaro
Engine: 5.3l h/c/i
Transmission: t56
i have sportlines with tokico 5 way adjustable shocks and struts and i love the way it rides! feels like a cadi when its on about 3 and then you go up to 5 its more stiff and you can take a 90* turn at 50mph!
nalls426's Avatar
Car: 1991 Rs Camaro
Engine: 5.3l h/c/i
Transmission: t56
Antips16
Oct 30, 2015 06:42 PM
Nervous2
Oct 8, 2015 10:53 PM
gta_knight
Sep 23, 2015 04:59 PM
jbates346
Sep 22, 2015 05:22 AM
Chiknhawk
Sep 10, 2015 08:55 AM
