Clear endlink bushing on rear?
Old Oct 27, 2002 | 09:38 PM
sllt1776's Avatar
Car: 89 Iroc-Z
i just recently replaced the bushing on both sway bars. the front were the expected black rubber. the rears were or used to be clear but they also were a harder durometer bushing about the same hardness as the new poly ones. i'm almost 100% sure they are original since the lady i bought it from never changed anything, not even the fuel filter. is this something anyone has hear of? is it possible i may have got a set of 1le endlink bushings on the back? thanks for the help.
Old Oct 28, 2002 | 02:57 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
The 1LE end link bushings are white and are made from what appears to be a hard nylon material. I believe they also have a pink colored band around the center section. Much harder than the rubber or even the red urethane Z28 bushings.
Old Oct 28, 2002 | 02:59 PM
P.S. - that pink band is around the center of the end link, not the bushing.
Old Oct 28, 2002 | 04:31 PM
sllt1776's Avatar
Car: 89 Iroc-Z
well thanks. the pink band may have dissappeared but the bushings were clear or white at one time. well they got replaced anyways.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
NBrehm
Aug 5, 2015 07:57 PM
