Maybe a dumb question, but I'm curious . .
Old Nov 6, 2002 | 07:17 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
A tubular designed sub-frame connector is supposed to be torsionally stronger and a squared/rectangular designed connector should resist a bending force better right? If that's true, has anyone ever thought about a triangular connector? I'm sure it would be more difficult to attach to the car but I just can't see why it would be a bad design. If what I said was wrong then just ignore this post and let it sink away. Thanks.
Old Nov 6, 2002 | 10:55 PM
SteveSpohn's Avatar
The only material close to a triangle is an I-beam, which weighs a ton. Great for buildings and bridges, but not for a performance car chassis.
What you do is triangulate the tubular framing. Look at any tube frame chassis and you'll see a ton of triangles. That's how you get strength and rigidity without the addition of a major amount of weight.
Look at the installed pictures of our SFCs and you can see the triangulation that is incorporated.
Steve
Old Nov 7, 2002 | 02:36 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Re: Maybe a dumb question, but I'm curious . .
oops, never mind
Clem
Old Nov 7, 2002 | 07:59 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I've always wondered why triangular braces weren't used, lol. So you just use round tubes and triangulate the way it attaches, like attaching the sfc to the inner part of the subframe? I can see how that would make sense. Thanks for clearing that up Steve.
Old Nov 7, 2002 | 09:16 PM
MdFormula350's Avatar
this was not a dumb question, you brung out a good question!
redmaroz
Apr 25, 2017 07:14 AM
RedLeader289
Jan 22, 2016 03:05 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
