Correct Prop Valve?
Subscribe
Nov 13, 2002 | 07:27 PM
First off, I have done a couple of searches, but I just want to verify if I am correct. I know it can be a pain to have the same question asked over and over.
I am swapping my stock 87 drum rear to a 94 PBR disc rear. I am confident about everything except the proportioning valve. I looks like I could use any prop valve from a 90' and up rear disc car. Is this correct? So any fourth gen valve would work?
Also, could I use a prop valve from an 87 disc rear? I know it did not have PBR's but would it be fairly close to the correct line pressure?
I would perfer to use a stock prop valve so that I do not need to mess to much with the brake lines and flaring the ends.
Thanks all,
Bill
Reply 0
Nov 14, 2002 | 05:16 AM
How about a GM part number 10164112 prop valve?
Reply 0
Nov 14, 2002 | 08:13 AM
"It looks like I could use any prop valve from a 90' and up rear disc car."
You are incorrect! You will need a propotioning valve from an early '89 Fbody. This old post by me, may help you; https://www.thirdgen.org/techbb2/sho...threadid=59878
You are incorrect. Find a GM dealer, and get a new 3rdgen Fbody valve.
Thanx,ANDYZ28
Reply 0
Nov 14, 2002 | 11:47 AM
Thanks for the fast relpies,
I looks like I will use prop valve 14089496 as opposed to 10164112 since my car is a 87.
Thanks for the help and let me know if I am wrong.
Bill
Reply 0
Nov 14, 2002 | 02:35 PM
Oh, just to verify,
is a '87 prop valve NB 35 KH 044 7 a:
86-88 J50.................14089495
or
86-87 JE1.................14089496
or
86-88 J65.................14089497
Thanks again,
Bill
Reply 0
Nov 14, 2002 | 08:36 PM
Thanx,ANDYZ28
Reply 0
Subscribe
