a arm bolts
Old Nov 14, 2002 | 01:37 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
a arm bolts
i', rebuilding my a arms, i have the ball joints and bushings and it seems everything i take off my car , the bolts break due to rust. any body change these bolts so i can buy them before or are they a dealer item?not some special item like allot of these things are?
Old Nov 14, 2002 | 02:21 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It really helps to soak them good in penetrant a few days prior to working on them. If you do have to replace some, try to get a good one from your car and find a real hardware store and replace them with better quality stuff. If a junkyard is close, check there also. Otherwise, you're looking at the dealer. When you reinstall them, put a good coat of anti-sieze on them to keep them from freezing up again.
Ed
Old Nov 14, 2002 | 04:22 PM
craig's Avatar
Car: 86 camaro
i've tried to soak them but the strut bolts and all the bolts on the rear broke- illinois winters i guess. the new ones have been antiseized.the strut bolts were a grade 8 these probably are too
Old Nov 14, 2002 | 10:50 PM
dunnb's Avatar
always get new bolts when dealing with the suspension and not from the hardware store; that 2$ bolt that you think is a ripoff might save your life. all those pieces are under alot of stress and why risk breaking a bolt and wrecking. besides after they are torqued the bolts deform or stretch and loose their clamping ability
Old Nov 14, 2002 | 11:05 PM
vjo90RS8's Avatar
Car: 2002 Z28
i changed my bushings and balljoints just a few months ago and had no trouble getting them off. I just sprayed them with some WD-40 the day before
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
