Lower rear shock bolt?
Old Nov 14, 2002 | 07:38 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I cant find it either,,,,whats the bottom rear shock bolt torque?
Also why do they say inch pounds of torque....What I found it say 70....thats is but it doesnt say ft pounds....that just seems like to much..
help....
Old Nov 14, 2002 | 09:26 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
my book states 70 ft. lbs.
Old Nov 15, 2002 | 04:45 AM
MdFormula350's Avatar
Haynes books, states shock absorber to axle nut 70 ft-lbs...
Old Apr 18, 2008 | 10:39 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
Re: Lower rear shock bolt?
i just read that in my haynes too, it also says "156 lbs in" for the top bolt...is that the same as 156 lbs ft??? seems like a hell of a lot if it is, wheel lugs are only 100!
Old Apr 18, 2008 | 10:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
inch lbs are 12 times less than foot lbs. 240 inch lbs is 20 ft lbs
I just snug my shock bolts tight. Dont torque them to any specs, just tight by arm strength and wrench.
Old Apr 18, 2008 | 11:10 PM
Car: 92 Camaro RS
Axle/Gears: Stock
I did think it was maybe that, but it seemed too simple! LOL
Well as I have a torque wrench anyway it seems silly not to use it
Old Apr 18, 2008 | 11:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
however, 156 inch lbsfor the top bolt seems very light to me
i just compressed the bushings to about even with the washer
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Eric-86sc
Apr 3, 2016 03:52 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
