Quick swaybar question(s)
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Are the front and rear endlinks on our cars identical? Also what's the sleeve length?
Engine: 305TPI
Lon, since you answered my question, what is so special about the GM 1LE endlinks that you sell on your site? They are twice as expensive as a comparable ES set.
Axle/Gears: 3.45, 3.27, 3.27
Special? They are not special. I do have to amortize the cost of plating them into the price though. I try to price them competitively.
Lon
Lon
Engine: 305TPI
Let me ask it a different way.
GM 1LE Nylon-bushed endlink 10221779
$9.16 each or your zinc-plated version for $14.35.
VS.
Energy Suspension Polyurethane endlink set (2)
9-8117
$14 from Summit.
What are the pros/cons of using each?
VS.
9-8117
$14 from Summit.
Unless you plan to compete in F-Stock class of SOLO ll it won't effect you. Use whichever you want, they are comparable.
Lon
Lon
Sorry if this is repetitive, but I just really want to make sure. I can use these endlinks for the front AND back of my Camaro?
Yes. I don't have a Prothane catalog, so I don't have a picture of them. But they should fit both front & rear sway bars.
Lon
Lon
I determine the diameter of sway bars by measuring them with digital calipers set to metric mode.
Lon
Lon
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Car: 1990 Camaro RS
Engine: 96 LT1
Then I may have the wrong parts here. I ordered ES front and rear endlinks and they were slightly different in length. I havent put them in yet so I'm not sure what the old ones looked like.
Engine: 305TPI
According to the GM p/n diagrams on Deadbird's site, the front and rear endlinks are exactly the same. The part number is 464167.
I just wanted to say that I have found the answer I originally asked in print. It's not that I don't trust Lon's answer, I just felt this thread was starting to ask the same question all over again.
The sleeves should be the same length. I used ES kits and they are the same part number, although the sleeves are about 3/8" longer than the stock ones were.
Ed
Ed
Just a FYI, I've re-priced the TDS 207080 1LE plated end link kits and some other suspension items also. Basically I elliminated offering these to my wholesale customers. Since my wholesale customers weren't beating down my doors to purchase these for re-sale, I can now reduce the prices.
BTW, the glitches on my site that prevented you from registering or purchasing online have been fixed.
Lon Salgren
Top-Down Solutions
TDS web site
Lon Salgren
Top-Down Solutions
TDS web site
ok, let's say we're not so well endowed...
