suspension (60-40)or(80-20)ws6
Old Nov 21, 2002 | 11:55 AM
boussole's Avatar
Car: 91 ws6
Engine: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
Transmission: TRANSMISSION, MAN 5 SPD, B0RG WARNE
Axle/Gears: AXLE REAR, 3.42 RATIO
how to spred my weight front and back ?
Old Nov 21, 2002 | 03:25 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
ideally you want 50/50, they make battery relocation kits so you can put it in the trunk to even out the weight some
Old Nov 21, 2002 | 05:33 PM
boussole's Avatar
Car: 91 ws6
Re: suspension (60-40)or(80-20)ws6
ok but
im instaling new shocks on it
Old Nov 21, 2002 | 05:59 PM
Car: '87 Camaro LT
Engine: 355 L98
i'm not sure i understand what you are asking then. by putting new shocks/struts on you cannot change your weight distribution. you do that by adding/removing weight to/from the car.
Old Nov 21, 2002 | 06:07 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
maybe he is thinking like 90/10 and 70/30 ratings in drag shocks/struts
Old Nov 21, 2002 | 08:12 PM
icecold's Avatar
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
if you run on the street id say stick with the regular shock valving the others are for racing and not ideally suited to the street
Old Nov 21, 2002 | 09:41 PM
boussole's Avatar
Car: 91 ws6
I needed advice about the 60/40 kool and merci !
Old Nov 21, 2002 | 10:13 PM
boussole's Avatar
Car: 91 ws6
Do spring need servicing after 80 k if you replace the shocks should one replace the spring or they’re no point
Old Nov 21, 2002 | 11:15 PM
Car: '87 Camaro LT
Engine: 355 L98
you usually will not need to replace your springs unless they are sagging or broken in some way
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
