I need TRACTION!!!
Old Nov 23, 2002 | 10:24 PM
Rockin88305's Avatar
I need TRACTION!!!
I just recently did a bunch of upgrades to my 88 camaro. With all this new power (probably a whole whopping 220 or so from my 305) i cant get the tires to hook up at all. On the back i have 245/70/14 eldorado gt's but i have some serious wheel hop and even if im cruising at about 15 or 20 and i stomp on it i dont move and all you see are big clouds of smoke. Right now there are 2 things im considering doing 1. getting a set of traction bars 2. get the sleeve and weld the frame together. But since im only 17 i have a limited budget. So if anyone would have any suggestions as to a low dollar setup to help me get the power to the ground i would really appreciate it.
Old Nov 24, 2002 | 11:13 AM
bob8748's Avatar
your gonna need the traction bars (lift bars). relocation brackets for LCA's are mentioned a lot but I havent done that. You can also mount your battery in the passenger side of the rear "trunk" if you can call it that. Will need an outside kill switch though for racing. mickey thompson ET streets or BFG T/A drag radial tires would be great.
Old Nov 24, 2002 | 01:13 PM
MdFormula350's Avatar
id say get relocation brackets, rear lower control arms.. that should be a good start..
Old Nov 25, 2002 | 07:14 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
arnt traction bars for leaf spring cars?
Old Nov 25, 2002 | 09:03 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
posi
Old Nov 25, 2002 | 10:55 PM
bob8748's Avatar
I bought the SSM lift bars made just for 82-92 Camaro... There is that "follow a plan" thing again, now I cant use them. backhalving the car with ladder frames instead, not much room on a 33" axle.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
