Is this a good price for a front-end job?
My mechanic wants to charge me $250 even for replacing the idler arm, pitman arm,, tie rod, relay rod, struts + alignment and I'm gonna bring the parts.
Does this sound reasonable or not ? ( Keep in mind that I live in NYC, it' s expensive here
) Supreme Member
Car: 4
Engine: 6
Transmission: 5
Don't replace the Pitman arm, it's nothing but a dumb piece of metal with no wear parts. It doesn't go bad, ever, unless it gets bent in a REALLY bad wreck. It's a witch with a capital B to change, probably $50 of the labor at least, and won't do anything at all to your car.
Put new poly sway bar bushings and end links on it instead.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
