Will these wheels fit?
Old Nov 26, 2002 | 07:18 AM
IROCKER's Avatar
I just picked up a set of stock Z28 style 15X7 rims. I plan on using them as a set for drag radials, BFG drag radials sized 275/50/15.
My first question is do the 15X7 rims have a specific front and rear offset configuration like my stock 16X8 IROC rims? There is no stamped part on them like my IROC ones that says whether they are rears.
My second question is will these rims with 275/50/15 rubber on them fit without any rubbing or clearance issues? Has anyone tried such a combo?
Old Nov 26, 2002 | 12:24 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
not sure but take it to the suspention drive train board they can help
Old Nov 26, 2002 | 01:10 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I'm moving this to the susp/chassi/drivetrain board since this isn't TPI tech, but i'll answer your questions too.
1- No, the Z28 15x7 wheels didn't have different front/rear offsets
2- Yes a 275/50/15 should fit without any rubbing or clearance issues
3- Kinda yes. I ran 265/50/15s on the back of my 85 Z28 a few years back on 15x7 wheels as an experiment. They fit, but not very well at all. The rims are so narrow that it causes the tread to be rounded so that it's not flat on the pavement, and from the side the tires look goofy because the sideall is so far from vertical. Does not make for a great handling combo, nor is it conducive to good tire life (neither of which probably concerns you for drag race tires though ) It still hooked up pretty well for me though, getting the tire pressure right helps the contact patch somewhat.
Old Nov 26, 2002 | 06:08 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
I posted about this a while ago and did not get a great response! Thanks for the info Ed. I was thinking of useing them as a "cost effective" drag wheel. Since they are so dirt cheap that is!
Old Nov 27, 2002 | 08:37 AM
IROCKER's Avatar
Thanks Ed...great answers.
So you think they will hook up right though with 275/50/15? This would be with the pressure drop of course. You kinda got me worried when you mentioned about the tread not sitting fully on the pavement. Since this is strictly for drag racing and not for the street, I'm not concerned about handling or tread life. But I need it to work good with the drag strip though.
Old Nov 28, 2002 | 01:08 AM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Tires
Hey I run 295/ 50 / 16 on my camaro and she fits. Its is about 12.5 inches wide (whatever 295/24.4=s) and 27.6 inches tall.
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
