Im planning on getting subframe connectors for Christmas, and I need to know if you can weld them in if they have been powdercoated. If you have to sand the coating off, I won't worry with it.
you could/can weld over the coating, but ideally you'd want to grind it. birght and shinny 1" from the weld area is a good rule to follow to do a good job. SFCs and the factory sheet metal are so thin it's hard not to get good penetration and make an acceptable weld for the application.
ok, well I guess it's not worth the $40 when you're gonna just grind the powdercoating off. I guess I'll just use some black rubberized chassis spray stuff. That should work, shouldn't it? Its not like I'll ever see it unless I actually get under the car.
Dewey316
close
- Join DateMar 2001
- LocationPortland, OR www.cascadecrew.org
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1990 Camaro RS
- EngineJuiced 5.0 TBI - 300rwhp
- TransmissionT5
- Axle/Gears3.42 Eaton Posi, 10 Bolt
- Liked:0 Times in 0 Posts
i replied in the other post you asked about this....
yeah, i started another thread because I kinda neded an answer fast. thanks though
i wouldn't use the rubberized undercoating, **** promotes rust, go with por-15 or something of that nature.
