Strut braces??? please look
Old Nov 30, 2002 | 06:26 PM
Kandied91z's Avatar
what is the quickest way to get strut braces off???
i found a 92 z28 and a 91 ws6 ta and they both have low miles so i'm trying to get the braces off since mine are worn. i removed the 4 bolts holding the plate to the tower; but the strut just spins when i try to move the main bolt!
what is the best and quickest way to rip these out of the car?
also, how would i go about taking one apart?
i'd like to have them chrome plated and i've been told they must come apart. anyone know of a type of shop that would do such a thing or where i could find out how to do it myself if it's possible. gm wants like 350 a pair for these bad boys so i'd like to get them out if possible...
Old Dec 1, 2002 | 11:26 PM
MdFormula350's Avatar
well you might need to use like some kinda clamping devise to hold the shaft of the strut from moving.. to get that main bolt off..
Old Dec 2, 2002 | 12:51 AM
Kandied91z's Avatar
no one has a good idea on how to do this??
i know there are people who have had to replace their struts before. how could you do it rather quickly??
Old Dec 2, 2002 | 07:43 AM
smurfmobile's Avatar
you have to cut the nut off
cut few of its sides off and eventually it will fall apart, new struts come with new nuts anyway
Old Dec 2, 2002 | 07:55 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If they're the stock struts, you should have a 10mm hex pattern on the top of the strut rod. Loosen it up like this:
Ed
PS: The KYBs I installed had an Allen wrench hole in the top of the new strut. See my page for other shots of strut install and removal.
Old Dec 2, 2002 | 11:19 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Strut braces??? please look
I believe they are spot welded together.
Old Dec 2, 2002 | 11:29 AM
Kandied91z's Avatar
thanks alot guys!
Old Dec 2, 2002 | 12:13 PM
kevosiroc's Avatar
If you have an impact wrench, you can just loosen them with that.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
