anyone know what this is?--> leak
Old Dec 1, 2002 | 08:33 PM
bigbrianiroc-z's Avatar
i have a leak on my rear passenger brake. they are disks all around, so there is a leak comming from this one screw/bolt, when it goes in it leaks brake fluid and when it goes out it stops, so i think that its some sort of pressure valve but im not shure so im asking yall tell me what u think.
Old Dec 1, 2002 | 08:37 PM
this picture is not good quality but it shows what is leaking
Old Dec 1, 2002 | 08:46 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
that is where the emergency cable is supposed to hook up. so the caliper is leaking brake fluid.
Old Dec 1, 2002 | 08:50 PM
mrr23's Avatar
Engine: 360 HSR
that is where the emergency brake cable is supposed to hook up to. your are leaking brake fluid.
Old Dec 3, 2002 | 08:24 PM
sorry for the slow responce but all i have to do is attach the e-brake setup and it sill stop leaking?
Old Dec 3, 2002 | 08:49 PM
mrr23's Avatar
Engine: 360 HSR
possibly. not sure. it will keep the stud from going inward. but may have damaged the seal.
Old Dec 3, 2002 | 09:58 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
It is really hard to tell in that picture, but it sure looks like the seal on that threaded stud that sticks out of the back of the caliper is leaking..... If the E-brake functions properly right now that would indicate that the hardware is at least attached to the caliper correctly (you would know if it wasn't as the bracket, cable, spring, etc would be flopping around back there and you would have no E-brake at all) and the seal is likely the culprit.
You can get a rebuild kit for the caliper that will include that seal and all the other ones inside the caliper through GM (most likely other vendors) but if the shaft of that stud is marred it won't seal properly and likely still leak. You can get rebuilt calipers from your local parts store but they are pretty expensive for that style caliper from what I have heard.....
HTH
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
