lowering 60'
Old Dec 2, 2002 | 05:54 PM
91 z28 350's Avatar
Car: 91 Z28
lowering 60'
ok my best 60' was a 2.051 with eibach springs and koni adjustable suspension which is set really firm was like that when i bought the car would changing the firmness help at all ? Also i am going to get spohn standard Lca's and Lca relocation brackets. will that help my 60' ? what other things should i look into for better 60'
Old Dec 2, 2002 | 10:18 PM
MdFormula350's Avatar
relocate the battery in the trunk, i believe unhooking the front sway bar helps, also run at least a 1/2 tank of gas.
a airbag in the right rear (passengers springs) should help.
make sure you have a good posi also.
Old Dec 5, 2002 | 01:02 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Get some v-6 rear springs and and adjustable torque arm. Remove the front sway bar and get some ET streets or ET drag slicks.
Old Dec 5, 2002 | 07:40 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
just did a 1.848 60 ft on 225/60-15 regular radial tires with monroe sens-a-trac struts and shocks, lakewood trailing arms and panhard rod. stock springs.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
