whats leaking?
Old Dec 8, 2002 | 08:34 PM
jbcmyk's Avatar
whats leaking?
hi guys,
anyone know whats causing this "leak", its on both sides under the rear seat. It seems to be coming from a round "pin" in the floor board under both rear seats, there's no dripping, just alot of moisture and its all over the torque arm at the axel.
see picture.
thanks for any ideas
john
Old Dec 9, 2002 | 05:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's water, it's leaking in around the T-tops and coming out those drain plugs.
Old Dec 9, 2002 | 09:28 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
looks like the rear pinnion seal is leaking.
Old Dec 9, 2002 | 11:56 AM
MdFormula350's Avatar
could be tranny fluid, rear end fluid or even water.
migt what to clean the area and then the next time it leaks you can identify the fluid/liquid.
Old Dec 9, 2002 | 06:36 PM
jbcmyk's Avatar
whats a rear pinion seal?
thanks
john
Old Dec 10, 2002 | 08:11 PM
82camaro's Avatar
Car: 82 camaro SC
If it's the rear pinion seal, it will leaking where the driveshaft's rear u-joint connects to the rear-end. Tranny seal will be coming from the driveshaft's front u-joint connects to the tranny. If it's coming through the floorboard, it's coming from inside the car--spilled pop, leaking t-top, etc...
Old Dec 11, 2002 | 12:26 PM
jbcmyk's Avatar
leaky
the car has been garaged for 4 months +, i dont drive it, i work on it. trying to restore to showroom condition + some.
its a 92 rs /305 tbi/ auto the tranny was rebuilt/replaced with a gm reduild unit from a dealer 2 yrs ago. So it can't be water from the ttops .
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
