front end moaning
Old Dec 9, 2002 | 10:06 PM
flowport's Avatar
front end moaning
Hey
I have an 87' Iroc-z that is having some issues.
When I drive straight down the street it makes this moaning noise, a little whoo, whoo, whoo, left cornering will increase the noise and moan but right hand turns make no noise at all and seems to be cornering like it should. Do I need tie rods? ball joints? wheel bearing? I have fairly new yokohamas on the front, could the tire be bad?
Any help would be appreciated, I just dont want the wheel falling off or the car falling flat on its face on the highway or something.
thanks
Old Dec 9, 2002 | 10:12 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Like you said..When turning the one direction is is bad, then the other direction it is gone..Wheel bearing for sure. It sounds like it is your passenger bearing. You did say it goes away turing to the right...right? If so passenger wheel bearing then. When turning left the noise increases because all teh weight is being applied to the passenger wheel bearings. I would just change both side anyways to avoid doing it agian to the other side at a later date.
HTH
Keiran
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
