steering loose
Old Dec 12, 2002 | 03:58 PM
ukz28-5.7's Avatar
Car: 92 z28
Engine: 5.7
Transmission: auto
steering loose
when driving my 92 z28 I have to turn the steering wheel more than an inch in the direction I want to turn to, before the wheels will turn.Is there any way of making the steering more positive by adjusting a component or does something need replacing?
Old Dec 13, 2002 | 08:51 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you can tighten the steering box. from the top there is a stud/nut. the stud has a hex key in the center. loosen the nut. then turn the stud clockwise one full turn. then tighten the nut back down. see how that does. also check the idler arm and center link for wear.
Old Dec 14, 2002 | 04:09 PM
ukz28-5.7's Avatar
Car: 92 z28
Engine: 5.7
Transmission: auto
thanks for reply.
When i turn steering wheel the lower and upper intermediate shafts turn,and will get the car jacked up to see if the pitman arm is responding properly. if so i suspect it is a steering linkage problem.
when you mentioned the steering box do you mean the power steering gear?
Old Dec 15, 2002 | 11:29 AM
mrr23's Avatar
Engine: 360 HSR
yes. what the steering column and pitman arm attaches to. the pitman arm is a non wearing component. you may be thinking of the idler arm. that is on the passenger side. attaches to the frame and centerlink.
Old Dec 16, 2002 | 04:17 AM
ukz28-5.7's Avatar
Car: 92 z28
Engine: 5.7
Transmission: auto
thanks for reply
I took my car in to local american car garage,and they said the steering box is worn. I can have it adjusted with shims or have it replaced,.All the rest of the steering components are ok.
thanks for your help.
Old Dec 19, 2002 | 11:28 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
So are you going to replace it? Would it fail an MOT as it is now? If you are going to replace it, where has them in stock in the UK?
Robert
Old Dec 20, 2002 | 06:06 PM
ukz28-5.7's Avatar
Car: 92 z28
Engine: 5.7
Transmission: auto
Ill probably have it replaced,the garage has a shipment from the states every couple of weeks,but they might be able to get it from the uk.It would probably be an mot failure depending on who does the test.
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Night rider327
Sep 25, 2015 04:19 AM
