Anyone sell stock ride height Hi-Po springs?
I need a new set of springs and I want to get a high performance set. Before you say get eibachs or whatever Im also trying to get the stock ride height back so I can keep my dual exhaust.
Ive seen some 1'' lower springs which would probably actually raise my car because I have stock springs with like 120k miles on them.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i get the NAPA brand. which are made by PERFECT CIRCLE. i order for a 1992 z28 with the highest spring rate. i can get you the part numbers.
here's what happened when we put them on a 1992 rs 305 tbi car. the stock springs were shot.
www.fl-thirdgen.org/frontspringswap.html
Car: 2004 GTO
From what I have heard, high mileage cars with stock springs are usually about 1/2 to 1" lower than when new from the springs settling.
If you want to keep the same height it is now, going to a 1" lowering spring will basically keep the height almost the same as it is now.
well the good news is Im getting a 3'' hooker catback for xmas so I will be able to take speed bumps again LOL. After I get the hooker 2055s I will have plenty of ground clearance again so I will probably go with a 1'' lowering spring. With my exhaust the way it is now its ridiculous.
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
