WTF!!! My lakewood lifter bars just broke!! Does anyone know about warranty??LOOK!!
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
My lakewood lifter bars just broke. Does anyone know if they warranty these, or am I just sh*t outta luck. If there is no warranty, would welding them hold them into place. (Like if I added some extra support or somethin). And also, since it is just the bottom part that snapped off, would my car still be safe to drive with it like that.(just for a little while) MORE PICS BELOW.
I've seen that more than once. They are known for that problem. I've also seen them break on the other end. It looks like you still have the LCA there, so you should be OK. Fort Meade huh?
The main reason why they will break is because your stock front torque-arm bushing is bad. The Lakewood traction bar setup is designed to assist the stock torque arm in planting traction. When the torque-arm bushing is worn, these will take the blunt of the force. For future reference-It is best to purchase a solid aftermarket "frame mount" style torque arm rather than using this assist type product. The stock torque arm mounts to the trans and then links to the unibody frame via 4 rubber mounts that all go bad over time.
Car: 84 Z28
Engine: 355
Car: 84 Z28
Engine: 355
Originally posted by MdFormula350
man that sucks, you might wanna try welding them.
Car: 84 Z28
Engine: 355
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'd try to call Lakewood and see what they say. Any reputable company should try to help you out or pro-rate you a new set.
Ed
Ed
Car: 84 Z28
Engine: 355
My father I guess you could call a professional welder. He works for walker machinery ( caterpillar dozers) and welds on dozers and stuff all day long. So, he is pretty experienced in this. I just took off the lifter bars and that still leaves the lakewood LCA right in place of the stock ones, so I am not going to be in too much of a hurry to replace them. I launched a couple of times today and it seemed to hook just as well as it did before.
Car: 84 Z28
Engine: 355
Re: Lakewood
Originally posted by CAMARO THUNDER
Whoo.. glad I changed my mind about getting those. I'm going with the SSM ladder bar setup now. BTW, How much horsepower are you making ? Thanks
gta892000
Sep 16, 2015 12:37 AM
dimented24x7
Sep 6, 2015 03:51 PM
