sway bar question
Old Dec 27, 2002 | 09:45 PM
Ghigman3's Avatar
Car: '87 IROC-Z
Engine: Modded 305 TPI
sway bar question
Ok say I have a sway bar I could put in my car. Is it going to make that much of a difference if its only a few centimeters bigger than the one I already have in the car?
Old Dec 28, 2002 | 03:03 PM
MdFormula350's Avatar
what size is the front / rear its good to have matched pairs.
Old Dec 28, 2002 | 04:16 PM
Ghigman3's Avatar
Car: '87 IROC-Z
ok well I had taken the rear end from this car and I switched it into my car and I swaped the sway bar with it and I was reading and found out the its good to have matched pairs so I went and grabed the front sway bar from the same car and put it in my car. have yet to see if it made a difference but now I'm on my way to the store so we'll see. Thanks for the help. don't know what the back one is but I found out that the front is now a hallow 36mm.
Old Jan 1, 2003 | 07:11 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
if your front is a 36mm then your rear is probably a 24mm. to take full advantage of these you need to use polyurethane or polygraphite bushings and end links to minimize deflection
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
