Yes. The rotor is separate from the hat. It is held on by 8 bolts I believe. I went with the 6 piston Superlite calipers up front and their 4 piston Superlites in the back. You don’t even have to use their rotors. I believe Performance Friction and a couple of other companies make rotors that fit to Wilwood’s hats.
No pics yet. I have the front torn apart right now. I am making some new adj. control arms and a cross member. When I am done fabing them up I will get some pic.
Hey Kandied
Go back and REREAD your other posts about Baer.. I bet you will find the answer....
Intercepter,Have you got the caliper mount brackets yet?are the calipers radial or lug mount?I've got a project going like this and the only way I can see to mount the calipers is radially.It is not an easy undertaking and would be great to see someone elses ideas.I'm not using Wilwood hats but one made by a company here in the UK.The cost of the front set up(with 6 pot calipers) will be a bit less than a Baer pbr kit,with only 2 pots!!!
Eric, I made the caliper mounts. They bolt up kind of like the 1LE calipers. I made a set out of aluminum first to get everything right, then I made the set I’ve been using out of titanium. It really wasn’t that hard. Wilwood has all the dimensions of their calipers on their site so I drew them up in AutoCad14 then machined them on a Bridgeport EZ Trak mill.
hey Skweezn87, i'm aware of what's in those threads. most times people don't always bother to search for threads like that and we get new people looking all the time.
no harm in asking the question. lighten up a little, it isn't like i'm asking about 4thgen seat installation.
should have pics up in a couple weeks when i recieve mine, just ordered them today! finally.
Quote:
Kandied91z
Didnt say there was any harm in asking... but asking the same questions over and over and over again....... well you get the point.Kandied91z
So what did you order???
i got the track kit with all the bells and whistles. i was going to go with alcon setup, but i couldn't justify the price even though i think the look sweet!
