sub and cage
Old Dec 31, 2002 | 10:45 AM
boussole's Avatar
Car: 91 ws6
Engine: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
Transmission: TRANSMISSION, MAN 5 SPD, B0RG WARNE
Axle/Gears: AXLE REAR, 3.42 RATIO
sub and cage
[ i plane to instal a sub frame on my therd gen and a cage my ?
is can i weld on the sub- 2 post up rigt on both side to be insert trou the flor in the rigt position and use that as post for cage]
Old Dec 31, 2002 | 12:25 PM
ede's Avatar
ede
most likely not, the two parts won't meet where you need them to. even nhra doesn't require a cage or roll bar to weld to anything more than the floor pan with a 6x6x.125 plate at the bottom of each tube.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
FueledSoul
Sep 30, 2015 09:18 PM
tmork454
Sep 29, 2015 06:33 PM
Bob88GTA
Sep 10, 2015 09:07 PM
