Brake Light
Old Jan 5, 2003 | 07:37 PM
REDRIDER89125's Avatar
Brake Light
My brake light doesn't work in my 87 T/A. The only time that it comes on is when I turn the key. If I pull the E-Brake on it does not come on. How do I fix this?
Old Jan 7, 2003 | 12:21 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
if it doesn't work at all, thats a problem, but it sounds like it works as long as the engine is on. The e-brake has never turned the brake lights on in any car or truck i've driven. It's not a big deal at all if the brake lights don't come on when the ignition is off, probally just means somewhere in it's life the source for the brakes was switched from constant 12v to switched 12v with the switch being the key...
doubt that helps any but that might give you something to check until someone else answers your questions better.
Old Jan 10, 2003 | 06:58 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
That's absolutely true! The E brake will not turn the brake lights on, if that were the case the manual trans cars would have a dead battery every morning
As a matter of fact, it wouldn't be normal, at least from what I've seen.
Regarding the key being on, it's not a biggie either, probably changed sometime ago. Don't worry about it, as long as they work during normal car operation.
Hope this helps!
Old Jan 10, 2003 | 07:29 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I think he's referring to the "brake warning light" in the dash not the tail lights. Yes, it should come on with parking brake engaged. It sounds like the connection or switch at the e-brake may be loose, broken or dirty.
Old Jan 10, 2003 | 07:57 PM
Davidgou's Avatar
OOPS!! Sorry about that, I thought he was talking about the tail lights, my bad!
Mine doesn't work either, if that's what you're talking about.
Old Jan 10, 2003 | 10:40 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It runs off a switch mounted on your brake lever mechanism, in the center console. It's probably stuck shut. Try some WD-40 or something.
Ed
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
