Some pics of new parts (Intrax-Baer-AGX-HMS)
Old Jan 15, 2003 | 01:15 PM
  #51
Nazzz28's Avatar
Car: 91 z28
Transmission: 700 R4
Old Jan 15, 2003 | 02:30 PM
  #52
TBI305Camaro's Avatar
Soon as I get normal exhaust again Im gonna lower mine. That suspension looks awesome. I was gonna get new heads this summer but I think Ill tackle suspension/rear end first. Would be better mod for the money right now.
Old Jan 15, 2003 | 03:24 PM
  #53
laiky's Avatar
Is the Baer bump steer kit adjustable?? or does it just lower the tie rod a fixed amount
Old Jan 15, 2003 | 03:40 PM
  #54
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
It's adjustable. It comes with a set of spacers to adjust the position of the heim joint.
Old Jan 15, 2003 | 08:20 PM
  #55
Tom Keliher's Avatar
I have my appointment for a "bump steer alignment" on Monday. Will be interesting to watch it done and then drive the car with everything set up right.
BTW, I drove my car around "as is" for about 1/2 an hour. When I got back and looked at my tires I was amazed to see how much they had been scrubbed. Just goes to show how important a good alignment is to tire wear, among other things.......
Old Jan 15, 2003 | 09:16 PM
  #56
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Re: Re: Im confused...
Originally posted by aklaim
Sway bar maybe? If thats what your refering to.
Im talking about the bar thats IN FRONT OF the sway bar. I see its a product from Spohn....Is that some kinda "dual" sway bar set up???
Later..
Old Jan 15, 2003 | 09:45 PM
  #57
aklaim's Avatar
Thats the steering brace, or "wonderbar" as some call it. Thats the adjustable model.
It goes:
Sway Bar---->Wonder bar----->Power steering return line...i think
Old Jan 16, 2003 | 06:13 PM
  #58
I thought the sway bar and the wonder bar were the same thing but just had different names....
Old Jan 17, 2003 | 02:06 AM
  #59
aklaim's Avatar
Nope, they are too completely different things. they mount up in the same place but they serve two different functions.
Old Jan 17, 2003 | 07:50 AM
  #60
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
What is the purpose of an adjustable wonderbar? What are the benefits of an adjustable over the standard version? Nice updates Tom,how did the interior work turn out?
Old Jan 17, 2003 | 08:35 AM
  #61
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Steve Spohn says it is to "Pre-Load" the brace.
personaly i don't see the purpose of an adjustable one, other than marketing but once again, i have not tried one, so who knows maybe it does help a little, but personaly i have always considered the wonder bar to be a peice designed to PREVENT damage, not as a part used to "improve handling".
Old Apr 11, 2003 | 04:37 PM
  #62
1fasZ's Avatar
It looks as if your rotors are on backwards according to the Baer website.
Failure to install rotors in the correct direction will cause premature failure.
Internally all Baer rotors are directionally ventilated and they must rotate in the correct direction of rotation to obtain proper airflow for cooling.
http://www.baer.com/Support/TechTips.aspx?TechTipID=2
Old Apr 11, 2003 | 04:59 PM
  #63
aklaim's Avatar
They are on right. Don't mistake the rear end for the front.
Old Apr 12, 2003 | 10:56 AM
  #64
Spdfrk1990's Avatar
Wow looks great i like everything u did i want to go redo mine like that now lol.I looked everywhere and could not find poly mount bushings for my 36mm bar ughhhhhh.
Old Apr 12, 2003 | 11:14 AM
  #65
JERRYWHO's Avatar
TDS has them, the link is at the top of this page.
Jerry
Old Apr 12, 2003 | 11:15 AM
  #66
Spdfrk1990's Avatar
1 more thing when u switch your front springs again did u loosen then a-arms bolts and take them out then when you put in the new just tighten them again with the weight of the car on them??? cause i wanted to maybe take mine back out wanted to know the right way thanx if ne1 knows.The first time i just took mine totally out and put in poly bushings.
Old Apr 14, 2003 | 02:56 AM
  #67
Scarebird's Avatar
Car: 1998 Z28 convertible
Transmission: 700-R4
As far as the wonderbar goes, would it be just as, if not more effective to weld in a piece of square tubing just forward of the steering box and at it's opposite spot on the other "frame" rail?
Old Apr 14, 2003 | 07:35 AM
  #68
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Where do you get a "bump steer alignment" at?
Old Apr 15, 2003 | 04:36 PM
  #69
Scott_92RS's Avatar
Car: 1992 RS
Do you have any pics of the car on the ground with the Intrax Springs? I'm looking to get rid of my Jamex springs, but I dont want to go much lower than I already am. How did the Bump Steer Alignment go?
Old Apr 15, 2003 | 08:21 PM
  #70
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
will the KYBs with stand the 2" intrax lowering springs?
Old Apr 16, 2003 | 12:57 AM
  #71
formul8!!'s Avatar
Car: 2004 GTO
Jeeeeez, Tom! You could eat off the bottom of your car!
Old Apr 22, 2003 | 05:17 AM
  #72
80's Al's Avatar
Car: 89' RS TPI,04' HEMI Dodge Q-cab
Engine: 383ci
Transmission: TCI 700R4, 3400 stall
Axle/Gears: 12 bolt 3.73
HMS mounts....
Where can I get a hold of these HMS strut mounts?
They look pretty beefy. I've been lookin for these and can't find them anywhere
I may go with the AGX strut, but set mine to "loose" for drag racing/wieght transfer.
80's AL
80' Berlinetta
89' RS (currently under construction for destruction)
97' BIG Dodge truck:hail:
Old Apr 22, 2003 | 11:30 AM
  #73
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Are those Baer Tie Rod ends suitable for daily driving on the street, both in terms of ride and reliability?
Old Apr 22, 2003 | 01:50 PM
  #74
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You'll be hard pressed to find a set of HMS mounts out there. Karl has only made 2 runs of them and who knows if and when he'll make more. You'd have to contact him directly at Hunter Motorsports. He's a board member also.
I'll sell ya mine...brand new and still in the box: $1000.
:sillylol:
Ed
Old Apr 22, 2003 | 01:58 PM
  #75
Dewey316's Avatar
Car: 1990 Camaro RS
i'm going to undercut ya ed.
i'll sell you a set, brand new, in box for $985
btw ed, when are you going to get around to installing those?
looks like i "Might" get mine on this summer
and Tom, any word on driving with the AGX shocks, i am still doing the great strut debate. i just can't deside, tokica, bilstein, koni, AGX
Old Apr 22, 2003 | 02:10 PM
  #76
Scott_92RS's Avatar
Car: 1992 RS
$950 SHIPPED, Freshly polished and clear anodized
I'll be in the market soon for some new struts as well, so I wanna here the results too.
Old Apr 23, 2003 | 05:29 AM
  #77
80's Al's Avatar
Engine: 383ci
Strut mounts
So, I guess I am not findin any, huh?!?!?!
Every time I look up Hunter Motorsports, I get these darn GO-Kart sites, or, BMW sites, nuthin pertaining to my needs.
If I could get an address or link, it would be great, if not, o'well, I guess.
thanks
80's AL
80' Berlinetta
89' RS(currently under construction for destruction)
Old Apr 23, 2003 | 06:29 AM
  #78
Dewey316's Avatar
Car: 1990 Camaro RS
i don't know if he has a website or not.
i have his phone number , and e-mail address at home, i'll PM you when i get a chance to get online at home.
Old Apr 23, 2003 | 07:33 AM
  #79
ebmiller88's Avatar
huntermotorsports@hotmail.com
I didn't find a website either.
Dewey, I don't know when I'll get around to putting them in. I was gonna wait until I got a set of Bilsteins but that may be a while, so who knows...maybe this fall.
Ed
Old Apr 23, 2003 | 01:42 PM
  #80
1fasZ's Avatar
Never mind I was looking at it backwards? Duh To many bong hits
Attached Thumbnails Some pics of new parts (Intrax-Baer-AGX-HMS)-standard.jpg
Old Apr 23, 2003 | 01:53 PM
  #81
Mathius's Avatar
Any reason why those HMS strut mounts couldn't be chromed, and if not, would that remove the visibility of the bead lines from the welds?
Mathius
Old Apr 23, 2003 | 02:18 PM
  #82
Dewey316's Avatar
Car: 1990 Camaro RS
my guess is it would still show the welds, you could probably sand the welds down and make it much cleaner. i am just goona run 'em, all go, no show!!
Old Apr 23, 2003 | 04:21 PM
  #83
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I had mine on for a week or so just to make sure things fit fine- they looked like crap so I pulled them off and had them polished. They are finally going back on next week along with my Koni's and Goodyear F1 GS-D3's. I'll get some pics when they are back on polished.
Old Apr 24, 2003 | 06:59 AM
  #84
80's Al's Avatar
Engine: 383ci
HMS strut mounts
Dewey316,
If you could hook me up with that info, that would rock!!:rockon:
E-mail me @ the following:
iam80sal@aol.com
Appreciate it.
80's AL:rockon:
80' Berlinetta
Old Apr 24, 2003 | 07:25 AM
  #85
Dewey316's Avatar
Car: 1990 Camaro RS
sure thing, i'll look for it tonight.
Old Apr 27, 2003 | 09:51 AM
  #86
Scott_92RS's Avatar
Car: 1992 RS
Any news yet?
Old Apr 27, 2003 | 11:40 AM
  #87
Spdfrk1990's Avatar
any 1 know where to get some good slotted rotors for 1le's
Old Apr 27, 2003 | 12:10 PM
  #88
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Powerslot rotors are premium quality and very fair priced.
http://www.powerslot.com/index.htm
Old Apr 27, 2003 | 12:34 PM
  #89
Spdfrk1990's Avatar
they dont have none for the rear
Old Apr 27, 2003 | 04:29 PM
  #90
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Here's another source with rears (slotted only) $204 per pair/ part # 55-022, 11.65" rotors 1LE (part# 55-51, 10.5" non-1LE)
http://www.raceshopper.com/sp_chevrolet.shtml
Old Apr 28, 2003 | 04:05 PM
  #91
Car: Yes...
Another option
http://cgi.ebay.com/ebaymotors/ws/eB...category=33564
I have a pair of the standard size slotted rotors from this seller on the rear of my car currently. No complaints thus far. I also have a pair of his 1LE slotted rotors waiting to go on the front. You can't beat the price.
Old Apr 28, 2003 | 07:07 PM
  #92
Spdfrk1990's Avatar
They look like there made out of cast iron tho it doesnt say
Old Apr 28, 2003 | 10:21 PM
  #93
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
metalhead... the bars go like this..
from left to right in the pic posted, sway bar, wonder bar, power steering cooler (the tubes themselves do the cooling), and then you see the radiator support.
I had an '86 that ran the ps. cooling lines up to the front bumper then back again, my '88 has them in the same place as the pic above.
Old May 12, 2003 | 10:15 AM
  #94
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
why does everbody think that his rotors are the wrong way just because the design isnt going with the forward direction.:lala:
Old May 12, 2003 | 10:32 AM
  #95
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
"Everybody" doesn't think that way- one guy did- we had this dicussion and settle things already that Tom had things correct with his rotors from the beginning- Read the post better.
Old May 12, 2003 | 02:12 PM
  #96
tbfirebird's Avatar
Engine: ??????????
okay 2.8 calm down
Old Feb 12, 2004 | 12:35 AM
  #97
25THRSS's Avatar
All I see is red x's. Would it be possible to get the pics back up please? Pretty please
Old Feb 13, 2004 | 02:00 PM
  #98
aklaim's Avatar
Holy old threads Batman!
Old Feb 13, 2004 | 03:10 PM
  #99
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Does Tom K even still visit this board? I'd like some more recent pics of this setup...
BADNBLK
Nov 16, 2016 09:12 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
