rear disc brake questions
Old Jan 7, 2003 | 09:20 PM
pskel350's Avatar
im looking to get a rear disc kit, its used and comes with everything for the rear axle.
what else do i need, just a disc/disc prop. valve? do i need a different master cylinder? do i need to get a different parking brake setup?
any tips or anything will be great
thanks
Old Jan 8, 2003 | 09:10 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What year is the brake kit off of? PBR kit or iron caliper style? I take it that it will be installed on your '85? Your car is also a disc/drum J50 car to start with?
Need more info.
Ed
Old Jan 8, 2003 | 11:44 AM
pskel350's Avatar
My car is a J50 disc/drum setup. I guess i should not of really could it a kit, its really like a used set up. its of from an 85-89 iroc, i am not sure exactly what year, and it includes everything i need for the actual rear disc brakes, but nothing else. I know i need a disc/disc prop. valve, but thats it.
Old Jan 8, 2003 | 01:01 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Re: rear disc brake questions
thanks
https://www.thirdgen.org/techbb2/sho...hreadid=115692
Thanx,andyz28
Old Jan 8, 2003 | 01:05 PM
ebmiller88's Avatar
I strongly suggest NOT getting it if it's the '88 and older iron caliper style. These calipers are known to lock up and not work right. Mine didn't. Definitely get the '89 and up PBR aluminum style.
Go with Andy's kit...everything you need in one spot.
Ed
Old Jan 8, 2003 | 03:45 PM
pskel350's Avatar
From what i can tell Andy's kit is over $700. I can get this setup for well under a $100. i was told that caddilac calipers will bolt up and still have provisions for the parking brake, will this work???
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
