break fluid change
Old Jan 8, 2003 | 02:52 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
break fluid change
my break fluid is about black and i want to change it. i've done it on motorcycles before but have never done it on a car. the way i do it on a bike is hold the brake, open the valve(with a clear hose on it). close the valve when the petal is compressed most of the way and do it a few more times untill there is enough in the hose and then just pump it out and keep filling it up untill it is changed. is it much different on a car? i wouldn't think it is much different because its mostly the same setup except a lot bigger.
Old Jan 8, 2003 | 06:42 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
just like bleeding brakes in a normal procedure...
what i did first was to draw out, remove, the fluid in the reservoir, clean the reservoir (just wipe it out, q-tips in the hard to get to spots). put you some fresh fluid in, bleed it thru the right rear, left rear, right front, left front - til you're all done. only pain about it is to make sure you keep fluid in the system so you don't "bleed it dry" while you're doing it. you'll need a couple of bottles to flush it out...
KAM
Old Jan 9, 2003 | 04:59 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
With the larger volume of car brake components you likely won't be able to do that trick of letting the hose fill with fluid and just pump the pedal. You will probably have to open the bleeder - depress the pedal - close the bleeder - release the pedal - repeat. The end result is the same.
Oh, and go to the F*rd dealer and get some of their HD fluid. Best fluid for the dollar out there and MUCH better than anything at the local parts store.
Old Jan 9, 2003 | 10:28 PM
SuperchargedRS's Avatar
Car: Camaro of course
just get a vacume bleeder tool ($15-25) and filll the cylinder up, un screw the nipple w. the hose on it, and scueez the vac untill you see no mor bubles. Alot easyer w/ the right tools
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
cstrobel65
Aug 15, 2015 10:19 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
