wheel-well liner rub
Old Jan 11, 2003 | 03:01 PM
russkull84's Avatar
Car: blue 84 z28
Engine: mildly modified 350
Has anyone had any problems with tires rubbing the top of the plastic wheel-well liner when using a 17" wheel? I recently added 17" ROH ZS wheels specially designed for the car and went for a test drive and noticed severe rub. The car has Eibach pros and bilstein shocks/struts. I also trimmed the bump stops down to take full advantage of the new suspension. Can I just remove the liners without causing damage to anything in the future?
Old Jan 12, 2003 | 08:50 PM
Kandied91z's Avatar
the liner is meant mainly to keep dibris out of select places and keep water from coming into the engine bay. if none of this concerns you then yes you can remove it.
what tire size are you running and how low is it sitting from stock?
i know of people running 20's with no problems so something is wrong.
Old Jan 12, 2003 | 09:44 PM
russkull84's Avatar
Car: blue 84 z28
I am using 255/45 Kumho 712's...I have seen others iwth this combo with no probs...could something be wrong? My car only sits about 1.5" lower than stock.
Old Jan 12, 2003 | 09:47 PM
russkull84's Avatar
Car: blue 84 z28
The only thing I can think of is that the springs arent in right.....I didnt line them up like most people do.....I just threw them in and called it good....could that contribute to the problem?
Old Jan 12, 2003 | 10:54 PM
Benny's Avatar
Mine has the stock 245-50ZR-16 and they rub a little when I back into my garage and have to turn the wheel to full lock, My car is stock height, when I had the Eibach pro kit on they rubbed alot espically with 4 people in the car.
Old Jan 12, 2003 | 11:03 PM
Kandied91z's Avatar
true, my 245's rub alot as well, but i modified my prokit so it's actually 2" drop in the front....
the placement of the springs can make a noticeable difference for sure. rather than guessing i'll wait to see if someone who has experienced this lends their expertise.
if you know of people personally with identical setups and no problems that raises a flag to me though.
MrPackstin
Oct 25, 2017 08:09 PM
Veaceonee
Sep 29, 2016 08:15 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
SlowAZ28
Sep 2, 2015 05:19 AM
