Help with damn steer brace
Old Jan 11, 2003 | 04:14 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I found out today that I am joining the group of oddballs whose global west steering brace bolt holes don't line up properly.
I'm beginning to think that the car they used as the template was in a front end collision, because mine never has.
Anyway....need to know the best way to widen the bolt holes to fit. I just tried a cobalt drill bit and that didnot seem to do much. What else can I fit in a power drill that will do the trick?? I don't need to drill new holes, just widen the ones already there.
thanks,
Old Jan 11, 2003 | 04:53 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Get a small dia. grinding wheel for a dremel and go to town on it.
Old Jan 12, 2003 | 03:12 AM
flyway190's Avatar
That's what I had to do to one of the holes.
Old Jan 12, 2003 | 07:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Strange. My Global West piece bolted right up.
JamesC
Old Jan 12, 2003 | 11:07 AM
I was thinking about this yesterday; I did not have my suspension loaded when I tried to bolt it up. SO when it stops raining today I'm going to try it with a loaded suspension and hopefully it will bolt up. I guess the the K-member spreads a little with the force from the loaded springs.
I don't have ramps so I was going to jack the front end up and put cinder-blocks under each wheel to get the needed clearance. Unless there is a better idea.
Anyway.....let see what happens
Old Jan 12, 2003 | 11:08 AM
bob8748's Avatar
Buy youself a dremel tool with all the bits and you'll never be sorry. One of the handiest tools I own.
Old Jan 12, 2003 | 01:42 PM
shawn87gta's Avatar
I bought one of these then my tranny went out before I could install it. I gave it to a friend and told him to just order me a new one. He had the car worked on and gave the brace to the shop to install for him, and they told him it would not line up. He called GW about this and was told they had a bad batch of them that would not fit. You may want to contact them before you start grinding on it, they may be willing to replace it with a new one.
Old Jan 13, 2003 | 12:58 PM
Hmmm...interesting. How long ago was this?
Old Jan 13, 2003 | 04:40 PM
shawn87gta's Avatar
It was about mid-year 2002, my car has been parked since the spring and it was a couple of months later that I gave the bar to my friend. I purchased it about a year ago, so if that timeframe matches yours you may have gotten a bad one.
Old Jan 13, 2003 | 04:44 PM
laiky's Avatar
My GW bolted right up, you should also check really carefully for cracking in the steering box area, that might explain it if its not defective.
Old Jan 13, 2003 | 05:04 PM
Well, this w/e I'll do exactly as the instructions say (i.e loaded susp.)
If that doesn't work, I'll look for cracks.
If it doesn't work, I'll expect its because of the Eibach springs and just grind the holes wider on the brace until it fits
Old Jan 14, 2003 | 01:09 PM
LILRED383's Avatar
My Global West Bar bolted right up also. I did have to bend that little tab flat, but other than that, perfect fit.
Old Jan 14, 2003 | 01:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Loading the suspension shouldn't make any difference at all.
The 2 ends are not the same. Have you tried every possible orientation of it? If it's like the GM one, it will only go in one way out of the 4 possible ones.
Old Jan 15, 2003 | 06:53 AM
Nazzz28's Avatar
Car: 91 z28
Transmission: 700 R4
Mine bolted right up also, and RB83L69 is right it will only bolt up
in one of the 4 possible orientations. I am pretty sure the mounting
plates point towards the rear of the car when it is mounted.
Correct me if I am wrong because my car is at the shop and I can't
check.
Old Jan 16, 2003 | 06:40 PM
you are right...the bar goes forward. One way is way off. Flip it over and its close....but with one hole lined up, the other three are off significantly. Sucks. I'll try again Sat morn
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
Night rider327
Sep 25, 2015 04:19 AM
