Replaced Manifold Brakes now shot
Old Jan 11, 2003 | 06:42 PM
89transam's Avatar
I just got done putting on a new TPI base, an accel . THe car is running O.k , but thats not whats bothering me. THe brakes are now almost completly useless, making the car not safe to drive. Did I disconnect my vaccum on accident? Where would I look to see if this is so?
any help would be great
Old Jan 11, 2003 | 07:05 PM
russkull84's Avatar
Car: blue 84 z28
Engine: mildly modified 350
check the hose going to the brake booster...would be pretty obvious if missing....make sure the hose going to it is in good condition as well....
Old Jan 11, 2003 | 07:08 PM
MdFormula350's Avatar
yeah i would recheck the hose(s).. if the brakes worked before something is wrong..
Old Jan 11, 2003 | 07:40 PM
radiateu2's Avatar
No brakes
You could have a serious vacuum leak causing a low vacuum situation. spray some carb cleaner sparingley where there is a gasket and listen for a change in idle. good luck. Oh did you install the check valve for the brakes backwards?
Reddeath210
Oct 6, 2015 08:20 AM
transaero
Aug 31, 2015 01:14 AM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
