Manual brakes for third gen camaro
Old Jan 14, 2003 | 10:40 AM
Flrodent's Avatar
Has anyone converted from power assist to manual brakes on a third gen camaro?
Whats the swap involve?
Old Jan 14, 2003 | 10:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There are some pictures on my web site.
First of all why do you need to convert to manual brakes? The weight saving from removing the booster "might" be 5 pounds at the most.
2 main reasons for converting are #1 you need more room in the engine compartment and #2 your engine doesn't produce a lot of vacuum for the brake booster. An electric vacuum pump or vacuum reservoir is easier than the conversion.
To convert to manual brakes you need a manual master cylinder. I found mine in an S10. The brake lines are on the opposite side of the master cylinder so rerouting lines is required. The manual master cylinder may also use double flare fittings and the third gen's metric bubble flare won't work. Depends on the year of your car. You'll have to adapt the lines or find aftermarket adaptors.
Mounting the master cylinder to the firewall is best done with a conversion kit but I just drilled new holes and bolted it on. The pushrod needs to be shortened and adapted to the brake pedel. You need to remove the brake pedel from the car and drill a hole 1" higher on the arm for the pushrod to attach to. This corrects the angle that the pushrod travels and increases the mechanical advantage for manual brakes. Older GM cars originally had 2 holes in the brake pedel arm since manual brakes used to be an option.
Old Jan 15, 2003 | 05:24 AM
Flrodent's Avatar
Manual brakes for third gen Camaro
Thanks for the reply,
The car in question will not see a lot of street use and I am not yet committed to making the change. Right now, the car is gutted and awaiting new paint, interior, etc. I am considering the swap just to clean up the engine compartment.
Again, thanks for the help!!!
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
